Hi srosen, thank you for your post, maybe I’m missing something, please somebody enlighten me, in this screenshot (see attached jpg) are a few examples of arrangements I came across in Revit.
You say that Revit is reporting the “net free area” that I like to call air stream size of a duct when tagged “Revit does know the air stream size is the important value - that is the duct size reported by the duct tag and the...”
(1) is showing a 300x300 duct with 25mm thermal insulation, when tagged is 300x300 which is correct (air stream size is 300x300)
(2) is showing a 300x300 duct and we apply 25mm insulation, when tagged is still 300x300 which is not correct should be 250x250 (air stream size) according to what you said above. (see Element Properties as well, Lining and Size)
(3) easiest example of a supply / return duct. You have to have the duct thermal insulated due to the amount of heat you have to transport. Inside the building you can have thermal insulation (is cheaper), outside the building you cannot have thermal insulation due to whether condition (can get wet from rain, snow…) so you need to line the duct, does the air stream size changed? No, according to Revit it does so you need to increase the physical size to keep the air stream size, resulting the #(3)
(4) example you need to have just 1 bend lined for acoustic reasons, what is the air stream size looking to the picture? To keep the size you have to enlarge the bend, resulting (5) or (6) if you need a longer portion of lined duct for acoustic purpose.
Maybe you are referring that Revit is indeed reporting the airstream size but doesn’t draw correctly, when applied lining could this be the reason? Which again is that I might be too picky and go again to the other extreme, require that Revit should be a drafting tool not only a design tool.
But now in the end I understand Kyle B (see http://discussion.autodesk.com/thread.jspa?threadID=655087) <
> I don’t know of any other convention, because I didn’t need to work with another convention other then this one, when I worked in Europe I used same convention I’m using now, sory to be an ignorant from this point of view.
