Would anyone will be able to explain how to put a duct mounted diffuser.
Thanks in advance
Gladson
Solved by asommer. Go to Solution.
You can mount the diffuser on the duct, but it won't "connect" to the duct properly for airflow and other values. since it needs a surface, what I do is create a "Reference Plane" where you want the diffuser, and place the diffuser on that plane. It will need to set off the duct a bit to allow room for the tap, but it will allow a proper connection.
