Revit MEP
Active Contributor
rschnureIV
Message 1 of 7 (875 Views)
Raster Image Draw Order
875 Views, 6 Replies
09-11-2012 08:54 AM
I have linked in a raster image into my revit mep 2012 project overtop of the architectural model link.  When I set the draw order to background, it does not mask behind the linked file.  Is there something I am missing?
Is the View's Visual Style set to Wireframe? This would prevent it from appearing as a background image.
CADastrophe
Message 2 of 7 (870 Views)
Re: Raster Image Draw Order
09-11-2012 09:13 AM in reply to: rschnureIV
Select the Raster Image and there is a parameter called "Draw Layer" under Properties. Change this to "Background".
Active Contributor
rschnureIV
Message 3 of 7 (868 Views)
09-11-2012 09:15 AM in reply to: CADastrophe
I did that, but it is not changing.
CADastrophe
Message 4 of 7 (866 Views)
09-11-2012 09:19 AM in reply to: rschnureIV
Valued Mentor
smbrennan85
Message 5 of 7 (491 Views)
12-10-2013 09:42 AM in reply to: CADastrophe
I must be missing something. I'm having the same isssue.
I create a new project, and to get started quicker prior to receiving DWGs or RVT files, we want to trace the geometry to create walls so we can start inserting wall-hosted devices, then align the walls later. We usually have PDFs. Since Revit doesn't support linking/attaching PDFs, here's what I did:
  1. Open PDF with Adobe Acrobat
  2. File -> Save As JPEG
  3. Create new Revit project
  4. Open Floor Plan View
  5. Insert Image
  6. Browse for Image
  7. Scale
  8. Draw walls
As I draw the walls, I can see that they're there, and I get alignments  for corners and what not. But, once that wall segment is complete, I no longer see it. I've tried background vs foreground, wireframe vs hidden, plan view vs reflected ceiling plan ... nothing is working. Am I missing something?
Thanks in Advance,
Shawn
Shawn B.
Follow me on Twitter @That85CADGuy.  ||    Connect with me on Linkedin.
To help improve Autodesk Products, please Click Here to provide feedback.
To help improve the use of these Forums, please  Accept As Solution and  Give Kudos.
Valued Mentor
smbrennan85
Message 6 of 7 (486 Views)
12-10-2013 09:46 AM in reply to: smbrennan85
Scratch that, I figured it out.
I had my view set to Electrical, therefore wasn't displaying.
once I changed my View's Discipline to Architectural or Coordination, I could see the walls.
Shawn B.
Active Contributor
DaveT4287
Message 7 of 7 (287 Views)
06-11-2014 08:17 AM in reply to: rschnureIV
Try clicking on the "Plot paperspace last" option in the print dialog.  Thast worked for me.
