Revit MEP Forum
Raster Image Draw Order
6 REPLIES 6
rschnureIV
6308 Views, 6 Replies
I have linked in a raster image into my revit mep 2012 project overtop of the architectural model link.  When I set the draw order to background, it does not mask behind the linked file.  Is there something I am missing?
6 REPLIES 6
CoreyDaun
in reply to: rschnureIV
Select the Raster Image and there is a parameter called "Draw Layer" under Properties. Change this to "Background".
rschnureIV
in reply to: CoreyDaun
I did that, but it is not changing.
CoreyDaun
Is the View's Visual Style set to Wireframe? This would prevent it from appearing as a background image.
smbrennan
I must be missing something. I'm having the same isssue.
I create a new project, and to get started quicker prior to receiving DWGs or RVT files, we want to trace the geometry to create walls so we can start inserting wall-hosted devices, then align the walls later. We usually have PDFs. Since Revit doesn't support linking/attaching PDFs, here's what I did:
  1. Open PDF with Adobe Acrobat
  2. File -> Save As JPEG
  3. Create new Revit project
  4. Open Floor Plan View
  5. Insert Image
  6. Browse for Image
  7. Scale
  8. Draw walls
As I draw the walls, I can see that they're there, and I get alignments  for corners and what not. But, once that wall segment is complete, I no longer see it. I've tried background vs foreground, wireframe vs hidden, plan view vs reflected ceiling plan ... nothing is working. Am I missing something?
Thanks in Advance,
Shawn
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
smbrennan
in reply to: smbrennan
Scratch that, I figured it out.
I had my view set to Electrical, therefore wasn't displaying.
once I changed my View's Discipline to Architectural or Coordination, I could see the walls.
Shawn B.
DaveT4287
Try clicking on the "Plot paperspace last" option in the print dialog.  Thast worked for me.
Rail Community
