I am new to Revit and I am adding lighting systems to a home. I have my lights powered and going to a panel as well as associated with a switch. The switch is currently unnamed when I look at the system selector. How do I add it to a circuit? When I click a light and then click the Switch Systems tab, it shows that the light is associated with the switch.
I want to make sure that the wire length is properly accounted for in the Electrical Circuits Schedule. Currently in the schedule, the Circuit Number says <unnamed> and the circuit Length says Not Computed.
The Switch System is completely separate from the Electrical Circuit. In order to connect the switch, hover the cursor over one of your connected light fixtures, press Tab until the Electrical Circuit becomes highlighted, left-click to select it, click "Edit Circuit" on the Ribbon, then select the switch.
