I've downloaded the Nibco ProPress elbow (PC606_PC607) from Seek and I'm getting a problem I don't know how to fix. I put the lookup tables in the right spot. I had a 45 deg Vic fitting that I changed to the PP fitting and it works correctly with one side disconnected. Once I reconnect the pipe, it wants to switch to a 90 deg fitting. The pipe is 4" and the lookup table has rows for 45 and 90 at 4". Anyone know how to fix this?
Solved by travis. Go to Solution.
I had the same issue. The way I ended up fixing it was a fluke to be honest with you. The connectors in the family I found out both need to be assigned to angle. See attached picture.
Travis was right. I went into the family and only one of the connectors was set to the Angle parameter. I set both to it and it's working great now.
