I have problem if i try to draw pipes in architectural tempalte. Is it possible to do it? If i draw in mechanical template there is no problem. If we can't create pipes in architectural, I can understand this. But, I am working in mechanical template and I have a revit link with architectural template as a backround. In the end, we were trying to join this two files. We tryied to copy installations from mechacical to architectural project, but program does not see pipes. What is the problem?
greetings
The Pipes Types are not set up in the Architectural Project Template - they have no Routing Preference established like the MEP Template does, so you can draw straight segments of Pipe, but it cannot automatically place Fittings. The best way to fix this is to open a new Project using the Mechanical Template, and use the Transfer Project Standards to Pipe Segments, Pipe Settings, and Piping System Types.
Thank You for reply. I have done this transfer, but I still can't connect pipes. There is something more, what should I do?
Error wchich I receive:
"The routing solution failed because is no default fitting type specified or the fitting cannot be found in the project. Ensure the fitting is loaded in the project and try again."
I checked, fittings are loaded.
The are not Routing Preferences established for that particular Pipe Type. The settings in this dialog control which fittings that Revit will use by default.
