Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
problem with pipe connector
2 REPLIES 2
306 Views, 2 Replies
I trying to create pipe connectors into sink. I made them, I set flow. When I connected it with pipe, there is no flow in this pipe. I tryed to compare this with other sinks which work, but I can't see the diffrence. What is wrong with this family?
I attach a file.
Thank You for replies.
2 REPLIES 2
thamizhz
im worked with ur family file.. nothing wrong. just reset ur pipe connector after check it out
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
www.TechRoom.bg
i try your family and works fine.
Try to reload the family in your project again and replace it 😉
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
