Revit MEP Forum
Problem when loading int o project
4 REPLIES 4
iamwhatiam1234
296 Views, 4 Replies
Hai
in the attached image
you can see the hilighted area
why that are coming when i loaded in the project
some times unfortunately when i click on that the size of the equipment is changing automatically
plzz advice
for ur refenrence i am attachment the family
4 REPLIES 4
Hey Raj,
This problem is because of the weak reference planes in the family.
Go to family editor and select the reference planes to which equipment boundary is attached or for that matter select all reference planes and change it to "not a reference".
Please mark this a soultion if it helps you.
PK
Hey Pk
i have a doubt
but when the other options are used like weak reference and all the references listed in "IN REFERENCE "
thanks
CoreyDaun
in reply to: iamwhatiam1234
Those grips are available when a Reference Plane is constrained to a dimensional constraint that is linked to an "open" Instance Parameter, meaning one that is not driven by a formula. One can prevent these grips from appearing in the Project environment by either assigning a formula* to the relative Instance Parameter (even if it's just "=1mm") or by selecting the Reference Planes and setting their "Is Reference" Parameter to "Not a Reference" (as per pardeepkumar536's post).
*Note that if one assigns a direct reference formula (i.e. for "Param1", formula " = Param2 "), then Revit maintains a bidirectional relationship, meaning that one can still change the value of the Parameter with the formula and it will subsequently assign the correct value to the referenced Parameter. In this case, the grips will still appear in the Project environment. In order to "lock" such a Parameter, use the formula: = if(1=1,Param2,0)
iamwhatiam1234
in reply to: CoreyDaun
hey corey d
thaks
got some information but not clear yet
