Revit MEP
Active Member
HZISEP
Message 1 of 4 (418 Views)
Problem copying pipes in Revit MEP 2012
418 Views, 3 Replies
09-17-2011 06:03 AM
 I have been piping up fixtures. I have sanitary sewer, domestic hot water, domestic cold water and vent. When I copy all of this piping to a similar fixture, all the pipe is put on whatever workset I am in. Isn't there a way to copy all of these sytems at once and have them not change what workset they are on? It srews up everything and wastes much time putting everything back on the correct worksets.
When elements get pasted, they are pasted to the active workset. So, if you have copied elements that are on different worksets, then pasting them, all of the elements will now be on the active workset.
The workaround is to make sure the elements selected are on the same workset, and that the desired workset is the active one when pasting the elements.
Valued Contributor
TonyVav
Message 2 of 4 (404 Views)
Re: Problem copying pipes in Revit MEP 2012
09-18-2011 09:38 PM in reply to: HZISEP
It sounds like you have each system on individal worksets. If so you should copy each workset individually. OR put them all on one (Plumbing) workset and use filters to separate them (which is the prefered way):smileyhappy:
Product Support
Chris.Aquino
Message 3 of 4 (375 Views)
09-20-2011 11:33 AM in reply to: HZISEP
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
Active Member
HZISEP
Message 4 of 4 (331 Views)
09-26-2011 06:35 AM in reply to: TonyVav
Thanks for your help.
