I have been piping up fixtures. I have sanitary sewer, domestic hot water, domestic cold water and vent. When I copy all of this piping to a similar fixture, all the pipe is put on whatever workset I am in. Isn't there a way to copy all of these sytems at once and have them not change what workset they are on? It srews up everything and wastes much time putting everything back on the correct worksets.
Solved by Chris.Aquino. Go to Solution.
It sounds like you have each system on individal worksets. If so you should copy each workset individually. OR put them all on one (Plumbing) workset and use filters to separate them (which is the prefered way):smileyhappy:
When elements get pasted, they are pasted to the active workset. So, if you have copied elements that are on different worksets, then pasting them, all of the elements will now be on the active workset.
The workaround is to make sure the elements selected are on the same workset, and that the desired workset is the active one when pasting the elements.
