DEAR,
MY SAVED PDF FILE, DUCT EDJES NOT SHOWN CLEAR, ANYONE HELP ME.ZOOM THAT PARTICULAR ARAE DUCT EDJES NOT SHOWN CLEAR,
Solved by BalajiHTI. Go to Solution.
Hi Raju,
It seems to me like it is a graphics card issue.... What type of graphics card do you have installed? Is it Autodesk certified?
It might also be the type of PDF writer you use and it's respective settings? A bit more information would help to determine the problem you have
Check befor print in sheet is that edge visible is good.If style is bad check view range.
Check your vissability/graphics override settings - projections/surfaces
Check your pdf print settings.
I hope this will be fix the problem
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
