Revit MEP
Member
emarcel8762
Message 1 of 4 (400 Views)
Printing issue in vector mode
400 Views, 3 Replies
12-20-2012 02:29 AM
Hi, I'm using Revit MEP 2013 (Win 7 64 bits - Quadro 5000K) and whenever I try to print, if I use vector mode instead of raster, I have issue (please see sample) in my prints when I use the "draw the hidden MEP lines" option. With raster mode, the ducts are correct but the prints are too blury. I'm trying to have correct drawings with quality prints. Any quick help would be greatly appreciated. Thanks.
Product Support
alan.quinn
Message 2 of 4 (344 Views)
Re: Printing issue in vector mode
12-26-2012 09:13 AM in reply to: emarcel8762
If you print to PDF do you get the same of different, or correct results?
Is this happening in all projects or just one?
If one, was the file upgraded from 2012?
Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Member
emarcel8762
Message 3 of 4 (318 Views)
01-02-2013 02:07 AM in reply to: alan.quinn
First, thank you for your anser.
The problem happens anytime I print (PDF or Plotter) in all my projects.
My template was upgraded from 2012, so I thing this might be the solution
to my problem, I will try with a new template.
Member
emarcel8762
Message 4 of 4 (282 Views)
01-14-2013 01:35 AM in reply to: emarcel8762
Well, I tried with a revit 2013 template and I came to the same result.
But after all I found the solution. My issue is due to the Rise/Drop duct symbols:
without the drawing is ok:
But as soon as I insert any Rise/ Drop dutc symbol it is wrong:
So I would like to know if those symbols are editable ? and if yes where can I find them.
Regards.
