Revit MEP Forum
pressure drop with ASHRAE tables
2 REPLIES 2
maurizio_moscoloni
707 Views, 2 Replies
Hello, sorry for my english but I'm italian.
I have a problem with the calculation of pressure drop in fittings.
The loss coefficient is equal to zero using the ASHRAE tables.
How to obtain pressure loss in fittings?
Thanks!
2 REPLIES 2
I have the same problem, but as i know the developer's of Revit, they cannot answer your question.
Its' really disturbing and boring, that i have to check the forums all the time, if have a problem. It needs more time, that i can spend on work.
Hello, someone solve the problem?
I'm italian too, if you will send me a private message...
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
