Revit MEP Forum
Plumbing System Copy
5 REPLIES 5
ToddKubicek
537 Views, 5 Replies
Greetings;
I am trying to copy a plumbing system consisting of water closets, urinals, and sinks and Revit gives me the following error:
"Can't move these elements at the same time. One of them is restricted to moving in one direction while the other is restricted to moving in a conflicting direction."
I am trying to copy and paste this system into identical restroom locations. Any help is greately appreciated!
5 REPLIES 5
I've seen this issue too, but haven't been able to isolate the cause (or even find a reliable repeatable case)... please contact product support, and please provide the dataset.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
ToddKubicek
in reply to: ToddKubicek
What is the best way to contact product support and send the dataset?
Help menu -> Create Support Request.
Martin Schmid
ToddKubicek
Thanks for the help!
I have had similar problems, and currently have a support request open (1-2558535661) that was submitted on 10/12/2007, so it
appears that it is a difficult problem to resolve.
One suggestion: to make a repeatable instance, just mock up an island vent, where the vent pipe comes up vertically, then uses 45
deg/90 deg/45 deg pipe and fittings to go back down vertically. This arrangement is always unmovable in either the "x" or "y"
direction, depending on the orientation of the angled pipes. To sum it up, if the pipes are drawn in the "x" direction, they won't
move in the "x" direction, but will move in the "y" direction.
I also had trouble mirroring pipes from one unit to another, but found that if you group them first you will have much better luck.
John
wrote in message news:5981850@discussion.autodesk.com...
