While making the plumbing layout i want the pipes above the cut plane to be visible as dotted line in my floor plan level. How do i do that?
Any suggestion is appericiated.
Solved by CoreyDaun. Go to Solution.
I don't think that there is a direct, easy way to accomplish that. The best solution I can immediately think of would be:
**Let me know if you have any trouble with any of these steps.
Thanks for the post..
Not able to get all steps completely...
pls find the attched file n correct me if i have put in things as required....
nothing seen in my file as for step 3 for checking the box.....
For step one, the Type of Parameter is incorrect. This field dictates what format of data the parameter uses such as length, voltage, an integer, etc. In this case, you'll need to set this parameter to "Yes/No" in order to create a checkbox option in the pipes and related families. Note that you cannot change the Type of Parameter after the parameter has been created, so you will have to delete it and make it again. Step two looked OK and it will work once step one is corrected.
