I'm trying to figure out how to create plan note call outs in revit. In AutoCAD we had a list of notes on the drawing, numbered consecutively (using a square symbol with number inside). Then on the plan, we'd call out items with the cooresponding plan note symbol. In Revit, it seems that all the tags are associated with objects. Is there anyway to make a generic tag with an editable label? Basically, I want to be able to place the tag anywhere on the drawing, then change the label to the appropriate number. In other words, I want the tag to be like a block with an attribute like in AutoCAD.
