Revit MEP Forum
Placing lighting fixture?
7 REPLIES 7
Message 1 of 8
jolieame
2096 Views, 7 Replies
When I put lighting fixture in the room, I need measure the length and width of the room, and calculate the distance between each lighting and the distance between lighting with the wall…so can put lights evenly corresponding to the luminaries spacing criterion.
Could I just roughly put fixed number of lights in the room, the distances between them will not calculated by myself, does revit can automatically adjust the layout evenly for this?
Thanks!
7 REPLIES 7
Message 2 of 8
AnmarieJames8335
in reply to: jolieame
To my knowledge, Revit will not evenly space your light fixtures for you. The dimensions between the fixtures themselves and between a row of fixtures and a wall will depend on the size and footcandle output of each fixture, as well as the desired/required total footcandles for the room.
The easiest way I have found so far is to place one light fixture in a room and use temporary dimensions and/or the Measure Between Two References tool to locate it correctly. Then, copy this light fixture (you can specify an exact dimension) as many times as necessary to create a row or column of lights. Finally, copy that whole row or column as many times as necessary to create the remaining lights.  You can go back and change the type of any light to emergency or nightlight fixtures afterward.
Message 3 of 8
jolieame
in reply to: AnmarieJames8335
Thank you AnmarieJames8335!
Message 4 of 8
m.voss.alvine
i made this to do this exact task.  give it a try.  drop it in your room and use the grips to stretch the sides to the walls.  you specify what kind of layout you want, 2 rows by 4 rows, etc.
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
Tags (2)
Message 5 of 8
bsammis
We use ElumTools for lighting analysis. The software comes with a layout assistant function that will space fixture based on your .ies file and desired fc level in the space. You'll probably still have to tweak the positioning a bit once it's done to fit into ceiling grids or whatever, but it can pretty helpful.
Message 6 of 8
fabiosato
Creating some lines between the luminaries rows, you can use equality dimensions. It is not the best solution, just an option, if you need to insert rows and lines you will need to adjust the dimension setting. To avoid some errors, create a equality dimension for each row and line.
Fábio Sato
Message 7 of 8
ehabjoin
in reply to: m.voss.alvine
thank you mvoss for this family it does not only help  placing the light fixture but also help and ac layout etc thanks again
Message 8 of 8
ehabjoin
Tags (1)
