Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
pipng/heating system
1 REPLY 1
408 Views, 1 Reply
i have to build in the room a heating system. The problem is that i don't can to connect my radiator and the boiler with the pipe. I must work with 6mm copper pipes. I have two pipe systems: returns and supply. When i use generate layout, the programm makes that but when i apply this it gives 5 errors (see attachments)
I am working with Germans familys for copper and I loaded the familys to routing preferences.
I have searches at the internet but found no solution the problem.
I am hopping that you can help with it.
1 REPLY 1
