I am doing piping. All my piping is going into seperate systems. I can't change the piping onto 1 single system piping system.
Any ideas
is this means when you choose the pipe involved you cannot change its system type?
Thanks for your feedback
Yes. I can't go back and change them all on to the same system. Each time I put on a pipe it added the pipe to a new hydronic system or other syatem
If you select all these pipes and Cut, paste them into another new file, do all go into one piping system? and if it does, cut pas them back to the main file.
Also i wanted to know that if Is this an upgraded file?
