Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Piping model regenerating is slowing me down way to much!
4 REPLIES 4
ddefrancis
1344 Views, 4 Replies
Im working on a sprinkler system in revit 2012, and its gotten rather large.
Now every time I connect a head to the system it takes a good 7-10 seconds to regenerate the model.  with more then 400 heads to go this is simply not going to work.
I have tried turning off calculations, and disconnecting smaller sections from the main system to work on(which helps but not much)
is there anything I can do here?
4 REPLIES 4
Chris.Aquino
in reply to: ddefrancis
I have some questions that may help to identify the issue:
How big is the file size?
Has it been audited and purged lately?
Are there any linked files, and if so how big are they?
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
Use Worksets to break the piping down into Zones and then turn off the worksets of already completed areas. In theory- when worksets are turned off Revit doesn't worry about regen'ing (if that's really a word) the elements in hidden worksets.
As far as calcs go - I didn't think Revit did calcs for fire protection due to liablilties, etc.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
aksaks
The answer is of course to not connect the sprinklers to the piping unless you really have to, as for a rendering, and when you do connect them, do it last. There is no need to connect sprinklers. You are not a sprinkler contractor, obviously because Revit is useless for fabrication plans, so there is no need to show connection details. Your or Revit's idea for how a sprinkler drop or sprig will be actually piped is fantasy. Furthermore there are many instances where sprinklers are required by code to be installed at angles to the view plane, as would be for any sloped ceiling or roof. Revit is unable to show the annotation symbol used to represent those sprinklers. Your properly connected sprinklers, and good luck with that, would not show up in a conventional plan. Your best option is to not connect sprinklers and to design the sprinkler family to be non hosted, containing weak reference lines that you would use the "Align" command for easily manipulating their locations relative to centerlines and common ceiling grid patterns.
abulla
in reply to: aksaks
Also if you have that many elements on one System it can cause serious slowdowns. We had a project with over 500 compressed air drops, and they were all on "Compressed Air 1". We had to eventually separate the compressed air from the rest of the model, and we had to further break up the compressed air piping into additional systems.
