I am in Autodesk Revit 2014, update release 1.
Can someone please enlighten me on the Pipe Type property of "clamp spacing"?. What does this actually do? I set it to 5' and drew a 40' pipe, and saw no results... Is this supposed to place hangers? Does it only show up in the schedules?
Solved by CoreyDaun. Go to Solution.
That is a Project Parameter - no such parameter exists in Revit by default. You can verify this by going to Manage tab » Project Parameters, and see if it's listed. My guess is that this was added by a third-party Add-In program.
You are right. I'm a goof. I think I created it myself a while back when trying my darndest to get some sort of hanger placement to work. I just forgot about it.
Thanks!
