How to change the system type of the pipe from other to hydronic supply? I cannot do the pipe sizing since the system type of the pipe I am working now is other. I want to change it to hydronic supply but don't know how. Please help me.
Select all the pipes by pressing tab till whole pipeing system is selected, of which you want to change the system, then goto filter check only the pipes, goto properties pallet there change the system type, automatically the system of the pipe fittings also change.
