I have added a some new pipework in a working view but when I go to the sheet view it doesnt display. I've checked everything I can think of, its within the view range, it hasnt been hidden and its visibility is ticked in the filter in the template.
Where else in that view apart from the template can a pipe system be controlled? The same filter is applied in the working view and works as it should.
Thanks in advance.
Solved by CoreyDaun. Go to Solution.
I just noticed the System Classification is under 'Hydronic Supply' whereas the other are under 'domestic hot water' etc, will this have anything to do it it? it's the only thing that I can see that is different between the pipe systems.
I can't change the system classification in the type properties as it's grey out, how do I do this? or better still how do I add this classification to display in the template?
There are multiple possible culprits that may be responsible for the hidden Pipe, the most likely would be Workset or View Filter(s).
One cannot change a Pipe System's Classification - it is set in stone and it depends on which Piping System is was duplicated from.
