Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe Stress Analysis
1 REPLY 1
teafoe5
2378 Views, 1 Reply
Does Autodesk have a program that is compatible with Revit?  If not is there a good program out there that is compatable with Revit that I can export my piping to?
1 REPLY 1
FXVIPilot
in reply to: teafoe5
CADmep and ESTmep are compatible with Revit. If you have them installed, you will find in your Revit add-ins RIF export tools. Export the piping to CADmep, then in CADmep you can export the piping as a .PCF file which most any pipe stress analysis tool will consume.
In the drawing area, right-click -> CADmep Utilities -> Export PCF File. –or– At the command line, type PCFEXPORT and then press Enter.
See http://knowledge.autodesk.com/support/fabrication-products/learn-explore/caas/CloudHelp/cloudhelp/20...
