Revit MEP Forum
Pipe Slope shown without Zeros
9 REPLIES 9
Message 1 of 10
BIMAbhi
1182 Views, 9 Replies
Please suggest us how can we see the pipe slope as 1% onstead of 1.0000% in Revit interface. We have attached a sanp for your reference
Thanks in advance!
Thanks & Regards
BIMAbhi
9 REPLIES 9
Message 2 of 10
in reply to: BIMAbhi
You can change the project units (Manage Tab-Project Units) for slope to be zero decimal places which will make a global change to the project or if you select one of the slope tags and edit type. Modifying the Units format will create a custom format for the slope annotation selected.
Message 3 of 10
BIMAbhi
Thanks for your quick response. As per your instruction we have changed the project settings in "Common discipline" as well as "Pipe discipline". After that we can't see the slope as 1% instead of 1.0000%. We have attached a snap for your reference.
Thanks & Regards
BIMAbhi
Message 4 of 10
danielkazado
                If you check the Suppress trailing 0's  box than you will see 1%  instead of 1.0000% in the ribbon where you select the slope.However  it did not change the apperance when the pipe is selected, it is still 1.0000%.
Daniel
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
Message 5 of 10
BIMAbhi
Thanks for the response. After check mark on the Suppress trailing 0's  box when we select the pipe w can't see the result. So can you please send a snapshot (process or result) where we can see the pipe slope will shown 1% instead of 1.000%.
Thanks & Regards
BIMAbhi
Message 6 of 10
danielkazado
  Please see attached where you will see the 1%. But as I mentioned it did not changed the instant view when you select the pipe, it is still 1.0000%.
Daniel
Daniel Kazado
Message 7 of 10
BIMAbhi
Agree with your suggestion. But we can't change as per snap 2  (slope value in your's 2 snapshots) which shown in 1%, 2%, 3% & 4%  for slope value. We have attached our snap. Kindly give us the process (Step by step) where we can get an idea. We appreciate your support!
Thanks & Regards
BIMAbhi
Message 8 of 10
danielkazado
Please find attached video.
Daniel Kazado
Message 9 of 10
danielkazado
in reply to: danielkazado
  I could not attached the video to forum but you may see it from youtube link below.
Pipe Slope Video
http://youtu.be/szUHmPayGIc
Daniel Kazado
Message 10 of 10
BIMAbhi
Thanks for the video file.
Have a good day:smileyvery-happy:
Thanks & Regards
BIMAbhi
