I'm having an issue displaying pipes on single line (course view). I have some risers that go up and down the building with connections then I have stub pipes that basically pop up in the room and drop below. Showing these on 'fine' view shows the yin yang symbol how I want it but when I switch to course my sub stack changes to a solid white fill. I have the rise/drop symbol set to yin yang for that system for all options.
If I put a bend/connection on the end of the stub stack then it appears how I want it. Can anyone shed any light?
Thanks in advance.
This appears to be the way it is supposed to work, and I don't really see a practical way around this. One thing that could possibly work would be to create a Union (no width and no geometry) that contains an nested Generic Annotation of the symbol you want, and then you could somehow hide the upper portion of the Pipe riser so the Union (and symbol) is visible on Plan Views. Not a very good solution, though.
