Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe insulation always 1"
2 REPLIES 2
bbrown
455 Views, 2 Replies
When adding insulation to pipe it always places it at 1" if it is less then 1", even if I change it in the "Add Insulation" dialog. To get the right size, I have to add the insulation, then edit it to the correct value (like 1/2"). If I place it at 2" it responds correctly.
2 REPLIES 2
CoreyDaun
in reply to: bbrown
Double check your Project Units; under the Piping Discipline, make sure that "Pipe Insulation Thickness" isn't being rounded to a coarser degree, such as to the nearest 1".
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
bbrown
in reply to: CoreyDaun
That was it. Thanks!
