Revit MEP
Valued Contributor
bbrown
Message 1 of 3 (151 Views)
Pipe insulation always 1"
151 Views, 2 Replies
03-07-2014 10:42 AM
When adding insulation to pipe it always places it at 1" if it is less then 1", even if I change it in the "Add Insulation" dialog. To get the right size, I have to add the insulation, then edit it to the correct value (like 1/2"). If I place it at 2" it responds correctly.
Double check your Project Units; under the Piping Discipline, make sure that "Pipe Insulation Thickness" isn't being rounded to a coarser degree, such as to the nearest 1".
CADastrophe
Message 2 of 3 (141 Views)
Re: Pipe insulation always 1"
03-07-2014 11:22 AM in reply to: bbrown
Valued Contributor
bbrown
Message 3 of 3 (139 Views)
03-07-2014 11:31 AM in reply to: CADastrophe
That was it. Thanks!
