Using Revit 2014,trying to draw a PVC pipe layout. Select Systems, Pipe and only have Pipe Types, Default choice in the Properties bar. So I manually select PVC under Pipe Segment and 3" under Diameter, draw the pipe and get a line. There is no 3D pipe image, no connections, etc.
Help!
Solved by rjhornberger. Go to Solution.
