Revit MEP
Distinguished Contributor
munsellh
Message 1 of 6 (1,860 Views)
Pipe fittings not scaling to pipe size
1860 Views, 5 Replies
08-11-2010 06:10 AM
I am placing 6" pipe, doesn’t seem to matter what type, and the elbow won’t appear larger than 1". the elbow fitting says it is 6", but only shows and measures as 1". see attached image.....
munsellh
Message 2 of 6 (1,857 Views)
Re: Pipe fittings not scaling to pipe size
08-11-2010 06:47 AM in reply to: munsellh
i figured it out..... my revit ini had a wrong setting
my LookupTableLocation was not set properly.
Active Contributor
onuswim
Message 3 of 6 (1,780 Views)
08-25-2010 04:47 AM in reply to: munsellh
I currently have this same problem.  Can you walk me through this process of how to fix this?  I can't really draw any of my pipe in until i fix this problem.  Thanks.
Distinguished Mentor
Jrobker
Message 4 of 6 (1,734 Views)
08-30-2010 12:55 PM in reply to: onuswim
Go to C:\Program Files\Autodesk\Revit MEP 2011\Program and open your Revit .INI file (notepad).
You will see the code that begins with
LookupTableLocation=
and
ENULookupTables.cab=
make sure that the paths are correct.
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
New Member
joedraftsman
Message 5 of 6 (1,272 Views)
06-28-2011 08:46 AM in reply to: munsellh
Here was the solution to my problem:
I found that in my Revit.ini file the LookUp file location line ended in the word PIPE, I just removed the word PIPE and everything works now.
That line and the ENU file location line do have to match.
LookupTableLocation=C:\ProgramData\Autodesk\RME 2011\LookupTables\
ENULookupTables.cab=d:\ProgramData\Autodesk\RME 2011\LookupTables\
Member
sllana
Message 6 of 6 (923 Views)
09-03-2012 01:57 PM in reply to: joedraftsman
Well, I did all of these and nothing happened, pipe fittings still not scaling to pipes.Except my ini file doesnt have the line ENULookup...    (but mine is 2012)
. . . and I couldnt add it because of administrator restrictions. could it be that? No further ideas?
p.s. please and thank you all.
