Solved by CoreyDaun. Go to Solution.
No attachment. There cannot be a disconnect between the Parameters and the Schedule; this sounds like it could be a matter of unit tolerance. Check your Project Units (and make sure to check your Schedule for format overrides) and ensure that it's not set to zero decimal points.
