I'd like to break out my fitting sizes into multiple columns while simultaneoulsy reporting them as numbers. Currently if I add the Size property to a schedule for an elbow I get 6"ø-6"ø. I would rather see this size broken into two different columns; each simply showing 6. My first attempt was to manipulate the string property with a Calculated Value, but that apparently isn't possible.
Any way to get this the way I want it?
Solved by CoreyDaun. Go to Solution.
You are correct in that manipulating (or even referencing) the text string is impossible. In order to accomplish this, you will have to create a pair of Shared Parameters and add them to every applicable Pipe Fitting Family. In each Family, you will have to assign a simple direct reference formula to each of these parameters. Once you have identified the Parameter within the Fitting Family that determines the size, add the formula = "[ParameterName]" to your Shared Parameter. You will then be able to access these Shared Parameters in your Schedule.
