If I am trying to insert a pipe fitting into my system those fittingsa rae behaving strangely and adopting an unconvincing size which is much bigger than the specified diameter of the fitting/pipe. Does ahnyone facing the same issue? I will appreciate if someone will share any workaround for this problem.
Thanks in advance!
Sivate Hussain
Thanks for your your resopnse!
I already checked the Revit.ini File for the location of the Lookup Table but it is the defined correctly where all the lookup tables are located.
I also check with Use Annotation scaling but is not making any difference.
I understand that the problem is only with the lookup tables beacuse it is just happening on one Workstation and the same file working fine on the other workstations.
Please guide. Thanks.
In a sanitary sloped system, I am connecting branches to the main using TEEs at 88 and 45 degrees. If I use annotation scale (say 5 mm) my fittings would look extremely larger on the 45 deg compared to the 88 deg. Is there any way to modify the annotation scale for a specific pipe size and angle independently?? Why would revit change so drastically the sizes displayed on my printing view, only by changing the angle??
the only workaround to this problem, I have found soo far is to turn annotations scales off for those fittings, but i am afraid this is not a "good practice".
