why does my pipe fitting annotation size setting not work in sections?? its works fine in plan? also the pipe rise/drop annotation size setting works fine in section, what am I missing??? thanks
Solved by Chris.Aquino. Go to Solution.
This is behavior that has been logged with our Development group. I am checking with them for any new information, and will update this thread when I get new information.
how do you shut off pipe fitting annotation? I accidentally turned it on, but don't remember what I did to turn it off.
Either independently within the properties of each fitting or globally (from that point on when inserting) in PS.
I have received an update stating that at this time, Annotation Symbols won't scale in Section or Elevation views. This is an issue that is being looked to be changed in the future.
If you would like to add your own comments about this issue, you can use the link below:
