I created an elbow that needs a ferrule end, I made it with a revolve but can not seem to get the revolve to constrain to the angle parameter or to the end of the sweep on the right side. I made a reference line to host which is flexing correctly. I even tried making the revolve a nested family but that did not flex correctly either.
Solved by L.Maas. Go to Solution.
I had a quick look at your model.
To properly rotate an object in Revit you would have to fix it to a reference line (not plane).
So a nested family (easiest) is a good way to go. Make sure (what you already did) that the nested family is “work-plane based” and “always vertical” has been set to off.
In the host arrange for a reference line and make sure it rotates properly.
Insert the nested family and attach it to the workplane and further constrain it to your needs
Have a look at this explanation
http://www.planta1.com/blog/rotating-a-revit-model-family-in-3-different-axes-by-reference-lines/
It explains in detail how to make objects able to rotate around all three axis.
Louis
Please mention Revit version, especially when uploading Revit files.
