Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Pipe down/pipe symbol perminate solution
2 REPLIES 2
dglenn9000
1286 Views, 2 Replies
I understand that a pipe will only show the pipe up symbol if connected to a fixture, endcap, etc.  This seems like a lot of added effort to have to add endcaps or hidden families just to show the pipe up symbol. In our model the the arch wants to own the fixtures, so we are just running the pipe up to them and stopping,no actual connections so it all shows the down symbol.
Is there a more permanent solution than described above?
2 REPLIES 2
CoreyDaun
in reply to: dglenn9000
If the vertical Pipe extends above the Top of the View Range, it will display the proper annotations, as well.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Chris.Aquino
Depending on what else is in the view, you could try lowering the top of the View Range to meet the pipe. That should also get the drop symbols to show.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
