Hello
I When the Dialog Object Steyle,Thickness line pipe Accessories Edition to 1,I encounter the following warning...
Sorry for the late reply...
Were you able to revert to a backup version of the file, prior to the appearance of the corruption? If the problem still persists, open a Support Case, which can be done on Autodesk's main website under the Subscription Center.
Some time ago, we had a similar occurrence, but I had traced the corruption back to the definition of two Families in the Project. I had opened a Support Case because I could not find a way to eliminate it. The Support Team sent it "up the line" to the Development Team, but I never heard anything about it. We ended up creating a new Project and copy/pasting the info over, since it was still early.
Hello
Thank you for your answer .
When this warning appears All backup files will damage And they could not be opened.
Of course I used the tool override by elements The problem was solved.
