I have an ongoing project we do both demo and new, and have an existing model from the client. The question s when we do demo, existing and new, how do we setup the views, each one for demo, existing and new, and how do I control the phases.
Thanks in advance,
Gladson
I am using Revit MEP 2012. This should point you in the right direction.
1.Highlight the existing building and all existing geometry. In the properties box make sure it says "existing" under phase created.
2. Use the sledge hammer under "Manage>Phasing". Under "Phase demolished" the demolished items will move to "new construction".
When you start drawing the new items they will go under "new construction" under "phase created".
I have a view for Demo and a view for New. Under "Phase filter" (In the properties box). I use "Previous + Demo" in the Demo view and "Previous + New" for the New view.
I usually don't change the phase filters unless there is an architect involved. If there is an architect involved you can "transfer project standards" from the Architects model.
Good luck
When setting up initial views, I recommend creating three per floor - Existing, Demolition, and New Construction, with the settings below.
View Phase Phase Filter Purpose
Existing Existing Show Complete Place ALL existing elements here.
Demo New Construction Show Previous + Demo Set the desired existing elements to Demolished.
New New Construction Show Previous + New Place ALL new elements here.
Thanks for the reply, I did as u mentioned, but for some reason it is not becoming half tone, even though I changed the graphic overrides to half tone in phase, could you please advise me.
gladson
Which View is not becoming half-tone? There could be a few causes, so tell me this: if you go to Visibility/Graphics » Revit Links tab and make the Link halftone, does that have any effect?
Sorry I forget to mention it, the existing view. as you mentioned the revit links are already in halftone
Gladson
No problem. This is expected behavior, which I'll explain how Revit interprets it:
The Phase of the Existing View is set to "Existing", which is like going back in time to when the original building is being constructed.
The existing Elements have a Parameter named "Phase Created" which would have to be set to "Existing" if they're showing in the Existing View.
Now, since we're "back in time", Revit is displaying all of these existing Elements as if they were New because they are created in this Phase (Existing).
The bottom line about the Existing Views is that they are NOT intended to be part of the final project, and they're just there for WORKING purposes***. So, their exact appearance should be of no concern. The New and Demo Views are supposed to ultimately be placed on Sheets.
***When you place a new element (a Duct, for example) in a View, it is assumed by Revit that it will be Created in the current View's Phase. Now, since the Demo View's Phase must be set to New Construction, any elements that are drawn in that view will be assumed New and then vanish, since New elements are hidden in Demo Views.
