We are facing some types of issues whenevre we are creating PDF from the Revit software and the attached snap illustrated the same for your better review. Please guide us with a probable solution regarding the issue we are facing.
Solved by arief.rahman. Go to Solution.
If it is printing fine to paper it could be your PDF driver. What driver are you using? I've never had any problems with the free cutepdf driver (www.cutepdf.com)
I like the way your pdf look...
We use bullzippdf printer which is free and every thing looks fine
Thanks for your valuable suggestion.
We have attached the snap which is creating by the help of CutePDF Writer. The problem will remain same. So please suggest.
Thansk in advance!
Hi RNDPIS,
Please make sure you have same setting for cute PDF as the attachment below. It is very helpful if you can attach also revit file source for this issue.
Thanks for your feedback. We have attached the revit file and a snap (Settings) for your easy reference.
