In my projects, I want to be able to modify the Duct Height, Duct Width, and Duct Radius parameters of the Duct/Fittings/Multi-Shape/Transitions, (see "Round to Rectangular Transition - Length.rfa" for this example) but for whatever reason these are set to read-only. Note that I do not want to modify any neighboring duct so that Revit automagically changes these parameters for me -- I want to modify the fitting's parameters directly.
To get them to be writable, I tried editing the family and setting the part type to something other than "Transition" (e.g. "Union") and then I could suddenly edit the parameters in the project. (Why is this? And, this won't work as a solution, since I can't modify all the system families this way.)
Investigating this further, I switched the part type back to "Transition" and then unlinked the Duct Height parameter from the rectangular connector. Now in the project the Duct Height was again no longer read-only. But again this isn't what I want -- parameter needs to be linked to the connector size to be useful.
So to summarize, there are two questions here -- 1) Why are these parameters read-only under this set of circumstances, and 2) Is there some solution that wouldn't require customizations to each of the families, e.g. maybe some setting at the project level that I could make to my project template?
Dimensions of this can be edited. Please see attached. When you select the fitting, the connector dimension shows up where you can select and edit it.
Hope this solve your queries.
