Revit MEP Forum
panel schedules
2 REPLIES 2
eomech4836
419 Views, 2 Replies
panel schedules
Is it possible to load a customized panel schedule into another project? We created the schedule layout we want and would like to save it for future projects.
2 REPLIES 2
abulla
in reply to: eomech4836
Sure! First, open both projects. Then, in the project you want to use the panel schedule in, go to the Manage tab, and pick Transfer Project Standards. In that dialog box, pick the other project from the pull-down menu, then check "Panel Schedule Templates" from the list, and hit "OK". Ideally you would do this in your template file or your dummy project file so you don't have to do this step every time you start a new project.
eomech4836
in reply to: abulla
Thank you for the quick response, I tried that and it worked perfectly.
