I really need help with this Panel Schedule. I did the steps out on the book and when I click the schedule icon, the schedule is blank and I can't work further the steps in order to make the schedule.
Is the schedule "blank" in that it doesn't contain any data or does it actually appear incomplete? Could you post an image?
Here's several files:
Hope this is enough information for you to help me out
Thank you and I hope that I get to hear from you very soon.
Your system is correct. The template is corrupt. I run into that problem as well and whenever I create a new project, the default panel schedules looks like that. You will have to Transfer Project Standards from another project in which it is correct. I think you could create a new RMEP 2011 project and transfer from that one.
If you could, can you please as best as you can tell me step by step how to Transfer Project Standards because I don't understand when you said that.
PS. I can't use 2011, I only have 2012
Thank you
Attached is a project with a correct panel schedule template. Open your project and open the attached "Blank Panel Schedule" project. In your project, go to Manage Tab » Transfer Project Standards. Make sure "Copy from:" is set to "Blank Panel Schedule" and then click "Check None". Scroll down and check the box for "Panel Schedule Templates - Branch Panel" and click "OK". A dialog box should appear, and choose "overwrite". This should correct the template in your project. This should also eliminate the warning you reported in your other post.
Thanks alot!! Now do I had to do it everytime I create panel schedules on every project?
If I have any more problems, I will come to you. (if you don't mind)
Again, thank you
You'll need to do that only until you create a Project Template.
Post whatever issues you'd like, but I'm not the only one who can help. Have fun!
I had a lot of problems yesterday, because I had the problem of corrupted panel schedule, But thanks to the info you have provided, today I have everything working perfectly!!!!! Thank you so much !!!!!!!!!!
