I have created a simple system and I have run all receptacles and lights to a 120VAC panel. When I try to populate a panel schedule, no information shows up. Any idea what the problem could be? The 120VAC panel LVP1 is the child of the transformer (T1) and the transformer is a child of HVP1. I am new to Revit so I'm sure it's something really simple that I am missing. I attached some screenshot in a word document.
Solved by CoreyDaun. Go to Solution.
Hello, and welcome to the Discussion Groups!
What is going wrong with the Panel Schedule, exactly? Are you just seeing a totally blank, and erroneous-looking Schedule? If so, this may be due to a corrupt version of the OOTB Panel Schedule. If this is the case, open the attached Revit Project along with yours and use Transfer Project Standards to import the "correct" definitions of the Panel Schedule Templates.
If the above does not solve the problem, please explain what steps you are taking and what you are experiencing.
It iwas a totally blank schedule. I transferred your template and I'm making progress. But no values populate. I attached a screenshot of the schedule and the settings for the panel schedule.
I found my screwup. For some reason, a panel wasn't selected for my lights and receptacles. Everything is good now. Thanks for the help.
