When I use a <parameter> to define a value in a panel schedule template, the result is 'blank' until data exists to populate it. But if I use a calculated value to define a value, it defaults to '0' instead of 'blank', thus causing my rows to look different. Any way to make this act the same? I'm attaching an image and a v12 model. Thanks!
Dustin
Would it be plausible to just change the direct Parameter References into Calculated Values to make it display consistently? For example, in lieu of just linking "K Connected" to a cell, create a Calculated Value with the formula "= K Connected"?
In my add-in, I ran into a similar problem. My was a little different--for a numeric parameter, it is blank until you give it a value, and then always has a value. There's no way to go back to blank.
I ended up choosing to use string parameters and do the conversion from a number to a string manually. That allowed me to also use a blank string when I wanted it to not have a value.
I'm not sure if it is possible or not, but can you use strings as your final output instead of a number? I haven't done much work with panel schedules or calculated values. If you can embed just a little bit of logic in the calculated value (a basic if-then) you should be able to make it work.
Otherwise, I would go for a solution similar to what Corey suggested, where they are all calculated values and all display a 0. Otherwise I think you'll run into cases where you can't get the parameter back to be blank after filling in a value.
