This is an issue we have just noticed in the last couple months. A large percentage of anything that is 2 pole. Does not split the VA in a panel schedule. Screenshot attached. Anyone have any ideas why and how to fix it?
Thanks.
Solved by fabiosato. Go to Solution.
Hello Timmy,
Change the connector System type from Power-Unbalanced to Power-Balanced, but after you change this setting you will need to link the Apparent power parameter of the connector.
Fábio Sato
Hello owosan,
Check the video.
Fábio Sato
