I'm using two viewports to show my piping. One with single line piping above grade and one with double line piping below grade. When I overlay the two viewports the above grade piping doesn't break the below grade piping so they just print out all on top of each other. I've made sure to put in the above grade second so it's on top but it still doesn't break the lines on the other viewport. Any ideas?
Solved by CoreyDaun. Go to Solution.
Hello, and welcome to the Discussion Groups!
The MEP Hidden Lines and Gaps do not work between different Viewports; they only function between elements in the same View.
The only solution that immediately comes to my mind is to alter the underground plan to show the gaps. In order to do this, the above-ground Piping must be visible on the underground View. Create a new View Filter with Filter Rules affecting only the above-ground Pipes and Pipe Fittings (if you don't already have one), add this View Filter to your underground plan, and set the color override to white (which essentially makes it invisible). Now on the Sheet View, the underground plan (which is underneath the above-ground Viewport) will appear to break around the single-line Piping.
As this is not a perfect solution (and I doubt that one exists), there may be undesired graphical effects in regards to the background and other elements, but I cannot say specifically without experimentation.
That gets me somewhere. My domestic water breaks the waste now. It's rough with the waste piping though because it's above and below grade. I don't know that I can differentiate between the two so it knows not to show one or the other.
That will take some manual work and another View Filter. Set the Filter Rules to "Comments Equals X", or something to that effect. Set the graphics to white, just like the other View Filter. Now for the manual labor part: You will have to select those elements that you want to be hidden in the underground plan and enter "X" (or whatever you set your Filter Rules to) in the Comments field, under Properties. If you are already using Comments for something, then you can add a new Project Parameter to accomplish this.
