Revit MEP
*Expert Elite*
LisaDrago
Message 1 of 4 (460 Views)
Accepted Solution
Omni Class Numbering
460 Views, 3 Replies
06-28-2012 12:49 PM
Hello - I have a client asking about Omni classifications - Specifically for fire protection - sprinklers and valves.
Any one know where I can obtain information about this?
I do not see it listed anywhere in the 'out of the box' Revit MEP.
Also - is this something that is being used and becoming part of standard requirements?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Valued Mentor
julianjameson8403
Message 2 of 4 (447 Views)
Re: Omni Class Numbering
06-29-2012 02:07 AM in reply to: LisaDrago
They are located in the Family Categories & Paramters within the families.
I think they are based on Table 23 of the Omniclass - if memory serves correctly.
I have attached a copy of Table 23 for you.
Somewhere in the back of my mind I think this topic was covered in an AU class a couple of years ago.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
*Expert Elite*
LisaDrago
Message 3 of 4 (435 Views)
06-29-2012 05:51 AM in reply to: julianjameson8403
Thank you do much for the pdf - I was about to find the fire protection category in there.
I was not able to find this category in the revit file.
Thank you again!
LD
*Expert Elite*
LisaDrago
Message 4 of 4 (430 Views)
06-29-2012 06:26 AM in reply to: LisaDrago
Okay - I was able to find the specific category - by changing the list to all categories in the dialog box - then I could access the fire protection.
Just needed to hunt a little bit more.
Thanks for your assistance.
LD
Announcements
Need installation help?
