Hi
I am producing a duct accessory schedule and would like to include the offset parameter in this which shows the height to the centre of the accessory from the level. The parameter is available in the properties panel but is not available in the shedule fields. see images attached. Any ideas how I can include this. any work arounds??
Solved by L.Maas. Go to Solution.
It is not possible to schedule the offset.
Workarounds tend to get messy. It would mean to create your own offset in the family.
After that you would have to make sure that the "Offset" created by Revit will not be used and kept at 0.
The biggest problem will be that the accesory is part of a system and as soon as that system starts to move up/downwards an offset will be introduced.
Therefore keeping an accurate offset wll be very hard/impossible to control.
That said, I never had the requirements to schedule an offset. Normally I will stick to elevation tags and/or dimensioned elevation views.
Louis
Please mention Revit version, especially when uploading Revit files.
Yes, still the case
You could use Dynamo to read the offset and store the value in another parameter that you put on the schedule
Louis
You can't expose it in the project but if the item is a family, you can build it in as a Shared Parameter (SP). You'll have two offsets to track but the SP is now in the schedule.
Hello @Anonymous,
As @L.Maas mentioned you could use a dynamo script to get the value from the Offset parameter and put it in your own parameter.
But be aware that you have to run the script to update your own parameter after Pipe offsets are changed!
You could use the Dynamo player to run the script after you updated your model and before closing your model.
Place the script in the folder with all other scripts and let the Dynamo player point to that folder.
Wonderful.! It's my first Dynamo Exercise done. Thank you So Much, & Do you have any packages like this or May I Know where Can I Get these *.dyn Files?
This was spot on!
Have been trying to find a work around for tagging/scheduling/filtering the offset of pipes and ducts.
This was my first venture into Dynamo, and the script you provided worked a treat!
Much Kudos to you!
Is it also possible to make similar script to get the reference level of pipes/ducts in the shedules?
Regards
It is possible, the same solution works for all system families, like cable trays, conduits, ducts and pipes.
Fábio Sato
I tried to do the same with a family specialty equipment but I get the error below (see image) ..
Thank you in advance!
Did you created a project parameter for myoffset or inserted a corresponding shared parameter?
Fábio Sato
I created a shared paramete 'myoffset'. Using the .dyn file that I found above it works..
So your problem is solved? It is not clear to me.
Fábio Sato
My first foray into Dynamo and the above code worked a treat.
I'm using mine to extract a list of mounting heights for Electrical items because the Contractor has specifically asked for this. The only issue is that 'Electrical items' in practice actually includes other categories, "Data Devices", "Telephone Devices" and "Communication Devices". They also stretch to include Fire Alarm, Lighting Devices, Nurse Call, Security and Speciality too.
Can the above script be run to 'repeat' for several categories however?
PS. I did find out that I could just copy the above into the same workspace just below and change the initial category (repeat for all categories) ...I thought this was a little crude ...but it did work.
So can the original code be changed to allow several categories to be updated?
Many thanks
Marc
You can use RF add in to create the schedule of pipe elevations in excel
