Anyone do much work with Nurse Call? I had to make some of my own families. I see there is an option for designing a system but what do I connect to. Is there some head end equipment I need to install?
The system is pretty generic and you will have to populate the circuit properties with Project Parameters for any kind of extensive data. Nurse Call devices should be of said category with a connector of the same type. They will connect to an Electrical Equipment family with the Part Type 'Other Panel' and same Nurse Call connector. You can create a Data Panel Template or create a schedule to use the information from the "Panel" the Devices and the Circuits as needed.
I am also thinking of installing Nurse Call Equipment. But while reading the reviews.
What reviews?
Did you have a question?
It looks like you posted without finishing your thought.
A friend of mine installed Nurse Call Equipment, everything seems to work well.
Let's see what happens next. Actually, I'm not sure if this is a very good idea. I once researched this topic using this site https://studymoose.com/becoming-a-nurse in college. You can also read it if you are interested. Maybe you can find an alternative for yourself.
Are you sure you posted the correct link? I don't see anything related to Revit and/or BIM.
